aliyuhussein avatar image
aliyuhussein asked
How to set depth of discharge
I would like to set a depth of discharge of 45% on my Quatrro inverter or color GX. In other words, once the battery capacity reaches 55%, then the system should either turn on generator or switch off. This is to avoid damaging my lithium batteries. Please can someone help to tell me how to go about it?
SOC
aliyuhussein avatar image aliyuhussein commented ·
Thanks so much sir. One more . How do i access the ess? download onto my computer and connect to inverter?
Kristof G. avatar image
Kristof G. answered ·
If you use ESS... go to setting and see min soc.
pietshaba25 avatar image pietshaba25 commented ·
@Kristof G. I have the similiar problem I did set it on ESS but it doesn't seem to cut off I have setted it to 60% can you please advise.
Kind regards
Piet
2021-07-07 at 15.21.02.jpegImage 2021-07-09 at 09.47.24.jpegImage 2021-07-09 at 09.47.05.jpeg
Hoi,
I think your grid is NOT connected, and thats why it does not work.
Connect grid to your inverter AC 1
