Do I need a GX device, MK3-USB adapter or something else for monitoring wattage?
Hi
Correct.
Kind of followup question: does Gerbo-S GX have the same functionality and more as MK3-USB-adapter? So it's possible to connect Windows laptop or Android phone to Gerbo using USB for monitoring and other stuff?
The CerboGX is used for monitoring the system, it's the gateway for connecting the system to VRM and some system settings can be adjusted within the menus.
It is possible to perform configuration of the MultiPlus via the CerboGX using either Remote VE.Configure or by using the VRM tab in VictronConnect.
83 People are following this question.
