I would like to use 2 Ruuvi temperature sensors to do an "If, then" situation with a fan relay. I would like my temperature relay to trigger if sensor one is above X temperature and sensor 2 is above Y temperature. For example, if the electronics compartment sensor is above 90 degrees AND the outside temperature sensor is above 60 degrees trigger temperature relay 1. I want to blow the hot air from the compartment out in the summer only. Is this possible?
