mivester avatar image
mivester asked
Connecting Lynx setup with Positive ground
I want to use a Lynx distributer system with a positive ground so that I can supply -48VDC to telecom equipment. I see that there is a dedicated ground point on the negative bus. Can I swap the bussing so that the polarity inside the units are swapped? or do I need to ground the bussing outside of the Lynx Bussing?
lynx distributor
