nan-wpg avatar image
nan-wpg asked
Ip22 charger question “user defined”
Hi. I’ve read the charger manual. I understand most of it, but the manual is not clear on user defined settings (or at least how it “works“)
for example I have a lifepo4 12v battery that the stock ip22 will not work. so I have parameters to input into the charger, and I know how to connect to “Victron connect” and modify the settings.
my question is:
once I’ve set the user defined parameters does the charger use the settings once I connect to the battery? Or do I have to select one of the modes (high, normal, recondition, li on). Specifically does “normal” work with the new parameters?
and does the charger only remember the last usage for stock settings (normal, high, recondition, li on) or will it,remember my custom parameters?
the manual is clear how to enter the settings I need but I’m now sure how to get the charger to use the settings
hope this makes sense
bluesmart ip22
