Hello everyone and thank you in advance for your help!
Here is my setup:
Im running an Multiplus 2 5000 most time on grid. But we experienced many long blackouts latetly so i switched our elektric heating system from AC-IN to AC-OUT1 and also our solar panels to assist an slower Battery discharge. Since the last times the Blackout was over night I bought an Generator and connected it to AC-Out2 with same setting in Venus OS.
I've searched the internet but couldn't find an clear YES or NO regarding the Multiplus 2. The Quattro is extra designed for that, this is clear.
Here is my question:
would it be possible to run the generator (if needed) also on daytime when the solar panels produce energy or does this setup only work at night time? Does the Multiplus feed in the Battery from two sources or will the Voltage from AC-OUT1 make interference on AC-OUT2 or even destroy my generator?
![victron-ody.png](/storage/attachments/52366-victron-ody.png)
