semlohnhoj avatar image
semlohnhoj asked
Does the Victron EV charger need a Type B RCD for single phase in the UK?
My understanding from the latest electrical regulations is that an EV charger should be fed with a Type B RCD if it doesn't contain an RDC-DD device internally in the unit.
The documentation for the unit mentions that a Type B RCD is needed for 3 phase but doesn't specifically say what is needed for single phase of whether it contains an RDC-DD device?
So:
1) does the Victron EV charger have an RDC-DD device internally in which case I can use a Type A RCD or
2) if it doesn't have an RDC-CC device then I'm assuming I need a Type B RCD even when using single phase.
ev charging station
semlohnhoj answered ·
For info:
I've noticed another almost identical question as mine posted at the following link:
https://community.victronenergy.com/questions/194765/have-you-installed-the-victron-ev-charging-station.html?childToView=200481#answer-200481
