ludog71 avatar image
ludog71 asked
Charge configuration with MPPT 75/15 and lead battery (Hankook DC24MF 80Ah)
I try to put good settings for my MPPT 75/15 with my lead batteries (model: Hankook DC24MF 80Ah). I have two battery in serie to have 24V.
Unfortunatelly, I found no details about my battery.
And I'm a bit lost, I found plenty of different settings on the Web and I can't figure out what is the good answer.
Could someone help me please ?
For the moment I have put those values:
Charging current: 15A
Absorption: 30V
Float: 28V
Equalize: 31V
Temperature: -32.40mV/C°
Thanks in advance
MPPT Controllersbattery charging
Michelle Konzack avatar image
Michelle Konzack answered ·
From what I see you would need to change values to
Absorption: 28,8V
Float: 27,6V
Equalize: 30,6V
Michelle Konzack avatar image Michelle Konzack commented ·
@LuDog71
with the Equalizing Voltage you must be careful, because not all Acid batteries want it that high. SOPzS or PzS are fine with 2,55V/cell, but 12V batteries might want only 29,4V.
Since the manufacturer give not any data out, you should try 29,4V first and see how they are bubbling and if necessary increase slowly.
Good luck and have fun.
ludog71 avatar image ludog71 Michelle Konzack commented ·
Thanks a lot for your answer !
I really appreciate your help.
