markus-schlehan avatar image
markus-schlehan asked
Can VRM connect to GX behind Cloud - Starlink using CGNAT
I use Starlink, means using CGNAT and having a not routable IP4 address. So there should be no problem for my GX to connect to VRM and sending data there. But how can VRM (or any other client) access the GX. We are in the planning phase and I dont see how this shall work? Starlink also offers business connection with static IP4 addressing, but thats far away from payable.
Any help or ideas here?
installation
nickdb avatar image
nickdb answered ·
Static addressing isn't required, next to no one has a static IP.
There are other users here with Starlink and it works fine.
There isn't a consumer ISP out there that doesn't NAT.
markus-schlehan answered ·
Thanks. ISPs use Carrier-Grade NAT (CGNAT) to conserve IP addresses. My ISP(Starlink) assigns a single IP address to multiple customers, and those customers rely on the same IP address. So I would mean, without any special effort, it will not work?
gone-sailing avatar image
gone-sailing answered ·
I use a LTE router and my system is behind carriers CGNAT. Everything works fine, including being able to connect to the GX's console remotely.
markus-schlehan avatar image markus-schlehan commented ·
Thanks Skipper, for sharing your know-how.
I am on Starlink and have no issues with any of the VRM or GX functionality, everything works as expected.
I regularly remotely connect to my system via VRM, and do two way communication to update firmware and settings.
Thanks Guy, that is interesting. You have a normal Starlink account, not a business one with static IP, don't you?
