mattfeldt avatar image
mattfeldt asked
Cerbo relais specifications?
Is it really true that the relais can only be used up to 125V Ac, meaning that one cannot switch 230V with say 10 Watts needed for an external relais?
Tx and sorry for the bothering...Horst Mattfeldt
cerbo gx
devodave avatar image
devodave answered ·
If you are only switching 10 watts you should be fine. AC is actually quite nice for relays to switch as the AC quenches any spark practically instantly.
