offgridcircuits avatar image
offgridcircuits asked
Alerts for Temp warning or overload on Multiplus?
I have a multiplus 2x120 and it often goes into temp warning. Is there a way in any system to get an alert when this happens? I have a cerbo, so an audible alert or message or email would would work to my iphone on the network. I cannot hear the cerbo from where I am inside the RV.
cerbo gx
Alexandra avatar image
Alexandra answered ·
@offgridcircuits
Is the system online?
If it is you can get push notifications.
If not there is a relay on the cerbo you could wire something up to and get a bigger buzzer or run a light to where you can see it.
offgridcircuits avatar image offgridcircuits commented ·
It's always online with a cerbo connected to the internet. I installed the app on my iphone to configure notifications It wants a portal ID. Been searching for this and cannot find it. Frustrating.
nickdb avatar image nickdb ♦♦ offgridcircuits commented ·
You just sign in with your vrm id.
Once done, add a widget for the site and enable push notifications. All in the docs or numerous other posts.
The portal id is on a sticker on the cerbo and listed in the vrm settings tab.
Alexandra avatar image Alexandra ♦ offgridcircuits commented ·
Portal id is found under settings -VRM portal menu....?
Push notifications set up links are in this blog.
You need to create a VRM account as well. Use the vrm app.
The alarm rule, once you have done the above 2 steps, is found in the side bar - settings+ - alarm rules....
