ene-katalin avatar image
ene-katalin asked
Help update invertor multiplus compact 12v 1200va
Hello, I have a victron multiplus compact 12v 1200va inverter, with series 1907132,
 I updated to 1907209 and when I access Victron Connect it tells me that the version is too old to update to 403. I can't find this version, is it possible to update or is it old  inverter?
firmware update
209 is the latest version for your device. The old processor (19) can't be updated to 4XX.
Unfortunately you can't use VictronConnect with your old device, you have to use VE.config.
ejrossouw avatar image ejrossouw commented ·
For clarity, he can use VictronConnect, but just not for firmware upgrades. Strange why a 19 series system does a check for 400 firmwares as it never supported it.
ejrossouw answered ·
209 is the up to date firmware version for your processor.
Firmware version 200 is required to see data and make changes to settings, but you cannot update firmware with it.
