tashbee avatar image
tashbee asked
Node Red MQTT - Just says connecting
Hi
I am trying to get MQTT within node red from my Multiplus II GX working.
I have followed all the instruction the following post but it just says connecting. I have gone through the instructions a few times to be sure I have not made a mistake. https://community.victronenergy.com/questions/174616/connect-to-cloud-vrm-mqtt-with-node-red.html
I have the port set @ 8883
I have the URL set at mqtt87.victronenergy.com
as per https://community.victronenergy.com/questions/155407/mqtt-local-via-mqtt-broker.html
One thing I noticed is that within the instructions I have not set anything under security.
I am sorry for the lack of detail in my question, but if anyone can point me in the right direction to work out why, I would be very grateful.
Thanks
Tom
Node-REDMQTT
gerard-van-seventer avatar image
gerard-van-seventer answered ·
If you are using node-red why not using mqtt from the Multi/GX itself?
You could use the cloudservice of course which really works if you follow the document but I always use the local broker, not only for reading data but also for (automatically) changing settings.
tashbee answered ·
Thank you very much for the reply.
The one thing I want to do is extract some historical data and also the total solar generated for the day, so that i can compare real world to forecast.solar.
Getting MQTT to the VRM platform would be handy also for the future.
Thanks
Tom
