Hi, my model firmware number is 1908142VFD, i cannot find the firmware for my model of Victron equipment. Any kind of help, links or advice is much appreciated, thank you in advance.
You can find all FW files here:
https://professional.victronenergy.com/
You need to use VEflash to update your device:
https://www.victronenergy.com/live/updating_firmware:updating_ve.bus_products
Thank you, i just found the firmware for my model 1908159, i just have one more question, i have firmware without assistants, can i install firmware with assistants which in this case is firmware number 1908209?
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
41 People are following this question.
