myvicrocks avatar image
myvicrocks asked
MQTT or Influx DB schema
Hi all,
I have searched but clearly not well enough, is there a wiki or documentation that explains the Influx DB schema (what each measurement means) or what each topic in MQTT stores?
Trying to understand the data first. Most the fields are prety self-explanatory by their name but want to make sure when I am building dashboards I am actually using the right value.
For example on the default "AC Loads" panel i see two default queries:
MQTTgrafana
nickdb avatar image
nickdb answered ·
https://github.com/victronenergy/venus/wiki/dbus
db tracks the dbus schemas, just drop the com.victronenergy bit.
All the multi info is under vebus, so:
vebus/Ac/ActiveIn/L1/Fvebus/Ac/ActiveIn/L1/I
vebus/Ac/ActiveIn/L1/V
These are the grid input readings for the first (default) phase.
myvicrocks avatar image myvicrocks commented ·
Boss thank you - clearly my searching skills are ***** thank you @nickdb
Have it setup now on all those values. The refresh rate is much better than the VRM portal. Lets see if I can pick up the drops from this thread - MultiPlus-II randomly starts inverting for less than a minute - Victron Community (victronenergy.com)
