robglover avatar image
robglover asked
Quattro connection to lynx distributor
I Have bought three quattro 48/15000. The manual advises that I need 2 x 95mm cables to connect to the battery busbar. I have two lynx distributors but each fuse space only allows for the connection of one cable not two. How do I connect the quattros to the busbar, whilst maintaining the recommended 2 x 95mm cables?
MultiPlus Quattro Inverter Chargerlynx distributor
Alexandra avatar image
Alexandra answered ·
@robglover
Get some professional help.
Fuse each cable separately 300A per cable.
You don't get 600A mega fuses for the distributor, or at least they should not exist they do not have the arc quenching ability.
Better to use NH fuse disconnect anyway there is a huge amount of things that can go wrong there.
robglover avatar image robglover commented ·
Thanks. That was my thinking. Just wasn't sure about paralleling two 300 amp fuses but I guess it gives the same result.
