Updated to version 2780502 firmware. I am seeing an issue when I "disable charger" . The charger does not disable. This was initially tried with charge current assistant set to "0", but manually disable did not work either.
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
39 People are following this question.
