So I have spent a couple hours looking for an answer to this. I found some good information but nothing definitive. Here is my situation...I am not getting useful battery monitoring from my CCGX with my 2xQuattros set to battery monitoring.
I want to use my CCGX for monitoring my system, especially using the remote console.
I have both CCGX VE.Direct ports used for my two MPPTs (both are 150/70, one has a CAN).
I have a BMV-712 that I can hook up to the CCGX but it requires a VE.Direct port on the CCGX, both of which are used for my MPPTs.
But I have read where one of my MPPTs (the newer unit with CAN connection) can be connected to the CCGX via a CAN port, that frees up one of the VE Direct ports for the BMV-712.
My question...Has anybody else done this and how did it work out?
And...Any other advice or suggestions for this situation? (Please don't suggest a Gerbo, wide says I am over budget already.)
