duncangardiner avatar image
duncangardiner asked
MulitPlus 2 48/8000 AC1 terminal poor quality
Hi I have an electrician attaching cables to various terminals of my Multiplus 2 48/8000 inverter.
One of the terminals for the AC1 output snapped off half way up. The electrician said he was hardly turning it. and it looks like there was a flaw in the bolt shaft of the terminal so I believe him. see image attached.terminal.jpg
I contacted the supplier of the inverter and they in turn sort advice from Victron Spain. Victron Spain said that a broken terminal is not covered by a warranty claim.
As I understand it, it's a soldered in terminal. Has anyone had the same issue? how did you resolve it. and if I need a repair done can a new one be soldered in without damaging the mother board?
There is just enough treads we think we can hack a solution with a bolt extension nut if no other practical solution is forth coming.
Thanks in advance
Duncan
Multiplus-IIterminals
