hugodevries avatar image
hugodevries asked
Shunt in positive or in negative wire?
I've just bought a battery monitor BMV 700. The wiring diagram shows that the shunt should be connected between the battery negative and system ground. I wonder why this is.
The only reason I could imagine is when using a wrench to tighten the bolts the tool can easily hit the surrounding metal housing and this will cause no harm.
Any ideas?
TIA,
Hugo
installation
wkirby avatar image
wkirby answered ·
It is in the negative side so the the Voltage drop measured over the shunt will be a positive value with respect to the negative of the battery.
The Analogue to Digital converters (like what's in the BMV unit) need to measure a positive Voltage with respect to it's digital ground which is referenced to battery negative.
hugodevries avatar image hugodevries commented ·
Aha, that's a good point.
Thanks!
