Wich name and location have the WiFi WPA config file in Venus OS V2.93 ?
"/etc/wpa_supplicant/wpa_supplicant.conf" is wrong.
The helpful commands "dir" and "cd" are not implemented in the Venus OS shell.
I need this info for solution of the problen that strong present 2,4GHz WiFi networks without WPA-PSK keymanagement will be not displayed and showed at the Venus GUI. It is not possible to connect a present wifi network, that is not listed at GUI ! This must be a confiruration problem because the same hardware (Raspberry pi 4) under Debian showes and connects the network, but Venus OS V2.93 (and also earlier) does not list it (also implemented on a Raspberry pi 3).
Thank`s for effort, i need the old present router configuration because my televisor does not accept WPA-PSK keymanagement.
Ulf
