how is that possible bp-220 connected to charge and discharge?
Hi @Boris
The lower unit in the pic is being used to control the batteries' charge. Note the comms connection to a bms.
From the datasheet.. "Note: the BatteryProtect can also be used as a charge interrupter in between a battery charger and a Li-ion
battery. See connection diagram in the manual."
Take another closer look and read the manual/look at the schematics in the manual.
33 People are following this question.
