Does anybody know if there is a metal bridge of some kind properly rated to combined 3 Victron 4 terminal bus bars together to make a 12 terminal bus bar? Many thanks in advance.
Nope. You have to do it yourself using a Flat Copper Bar and make sure it is big enough to support the current.
Looks like this thing might do it.
An alternative is to use multiple Lynx distributors.
Some people use copper pipe hammered flat instead of the bar that @Michelle Konzack mentioned. But I wouldn't recommend a bodge like that.
I can not more remember how broad the Flat Copper Bar was, but the thickness was 5mm and I bolted it over the two bolts in the middle.
My customer had 3 of it and I made bolts in the middle between the bus bars, hence to connect the 4 Batteries (each 48V, 200Ah) and then on one end of the Busbar the 3 MultiPlus-II 48/5000 and opposite in the middle nothig (for now) and on the left/right Busbar each a SmartSolar MPPT 250/100-Tr VE.Can.
In this way I have mostly optimised the power between the 4 Batteries, 3 MultiPlus-II and two SmartSolar.
The leftover in the middle could be a 5kW Windmill if not connected 3-oase to the ACout1 of the MultiPlus-II.
I do not know, why the OP want to join the 3 busbars, but it sound like he want to use what he has to connect some heavier loads on it.
34 People are following this question.
