rubicon avatar image
rubicon asked
Power for Touch 50
I am installing a Touch 50 and need to extend the USB power cable. I purchased a USB socket and attached 14/2 wire to the terminals. Can I attach the 14/2 gauge wire with ring terminals directly to the positive and negative power bars of my system? Is an inline fuse needed or required on the positive line?
cerbo gx
Kevin Windrem avatar image
Kevin Windrem answered ·
The GX Touch displays need 5 volts, so no you can't connect directly to battery. There are many DC to DC converters that provide a USB A connector as output and are 5 volts. There are many different voltage ranges for the input. Pick one with the proper range.
rubicon avatar image rubicon commented ·
Thank you for the reply. On my install, I ran a 14/2 wire attached to a Blue Sea USB socket located near the Touch 50 for power. It’s located appropriately 14ft from the Cerbo. I currently have it connected to my 12v panel with a 3 amp fuse. A separate power switch controls the power feed to the 12v system. I was advised to move the line over to the same power supply as the Cerbo. The Cerbo is connected to the main power bar after the main on/off switch. When the main switch is turned on, the Cerbo and Touch 50 will be powered on. As you know, the Cerbo has an inline fuse. I was advised to simply attach the positive and negative wires feeding the USB socket to the same bus bars/power bars as the Cerbo. I definitely don’t want to fry anything. Do I still need a DC converter?
Kevin Windrem avatar image Kevin Windrem rubicon commented ·
The Blue Sea USB socket is the converter. You'll be fine
