kevgermany avatar image
kevgermany asked
EasySolar not Charging from shore power
Looking for suggestions of cause please System Easysolar 24/1600 in campervan. CCGX Orion 12/24 10 from alternator to batteries. BMV712 mains hookup. Solar working fine throughout EasySolar switched on, no trips tripped. I disconnected shore power, went for a drive, came bac, reconnected shore power. Noticed a couple of days later that AC in was not working, despite 247V being recorded. EasySolar was clicking, apparently trying to go into charge, but not succeeding. Inverter working throughout. Tried all the obvious, setting no ignore AC in, replugged shore power, which although high, is within spec. No errors/warnings. Eventually found shore power was showing disconnected in the CCGX. Managed to clear this using Victron connect via MK3 adapter. Switching off using Victron connect dashboard didn't help. Switching off at the easysolar didn't clear it. System has been working fine for over a year. So any suggestions as to possible cause? Easier way to recover?
EasySolar All-in-One
