miya avatar image
miya asked
Battery Protect BP220
Hi All
Help please... Yacht 12v System...
4x 330Ah in parallel to Lynx Distributor > Lynx Smart BMS > Lynx Distributor. All loads come off Distributor. After the distributor I have 2x BP220.
  • 1 is used for house loads (very low Amps)
  • 1 is used for 2 winches (which will draw much higher Amps).
Testing winches today - 1 winch alone is pulling 100A - and both on are pulling about 200A. With both on, for a short time (seconds), the BP220 cut out for a short moment - then came back on - and I could smell a slight burning smell. I can only assume was the BP220.
Question - is the BP220 suitable for high load winches ? Is it suitable for high currents for short periods of time ? The Amps rating of the BP220 would suggest it is fine.
Any suggestions please ??
Thanks, Tim
Battery Protect
Jons Collasius avatar image
Jons Collasius answered ·
Take a look here:
https://www.victronenergy.com/battery_protect/battery-protect#downloads
Max. continuous load current: 220 A
Peak current (during 30 seconds): 600 A
You should be fine if your winches really draw 200 A combined. But your start-up current may be higher and the BP-220 cuts out.
With a DC motor, the starting current is approximately the current when the motor is stationary. So measure the resistance across the motor and calculate U/R=I. There you go.
