goozer avatar image
goozer asked
MPPT and Orion-TR Max Current
Installed -
Orion-TR Smart 12/12 30A
Smart Solar MPPT 100/30 - fed by 305W single Victron panel (so 25A max?)
TN Power (LifePO4) 100Ah battery
Installed in a 2022 Fiat Ducato
Battery spec states a max charging current of 50A. If both DC2DC charger and MPPT are running at max charging current this then exceeds the max charging current of the battery.
How do I know if the Amps from the van will ever reach the max 30A from the DC2DC?
Do I need to setup the MPPT or DC2DC config to ensure 50A total max? I do not want to throttle either solar or DC2DC ideally.
I appreciate that in the UK I'm unlikely to see both devices providing the max but I just want to understand and make sure there will be no issues.
Thanks
Guy
MPPT ControllersMPPT SmartSolarorion-tr smart
kevgermany avatar image
kevgermany answered ·
You're only going to get 22A at best from the MPPT (calculate at charging voltage, not nominal voltage).
But you're potentially over the charge limit. Usually the BMS will protect you. Unless you're intending to spend a lot of time in sunny places, I'd be tempted to do a sanity check with the battery maker, and leave as is.
Otherwise it's very easy to set a charge current limit in the MPPT using Victron Connect and your phone. Do that on the sunny days when you drive and don't forget to reset once you park up.
You could also set it permanently to 20A. You're going to lose almost nothing.
