Hello @Kevin Windrem
Have an RPI4 and the Canhat module for the BMS connection to the Pylontech..
I built the Canbus BMS cable type A myself.
Question, did you also connect the GND to the ground somewhere?
Can such an overrun occur due to the missing GND?
maybe it has to do with the Venus OS Watt display stops?
Thanks
