Hannes Swart avatar image
Hannes Swart asked
How to update a 3 Phase Quattro system
3 Phase system
CCGX
2 x SmartSolar MPPT VE Can 250/100
3 x Quattro 48/5000/70 2x100
30kVa Generator
My question is this, if I disconnect the CCGX and connect the mk3 interface then saved the settings in Victron Connect, after the upgrade and I load the settings again via Victron Connect would all the settings be reinstalled or would I need to use VEConfigure to set it up as a 3 Phase system again?
Excuse the dumb questions its just that I am in Mozambique and the installer is working out of country at the moment and I am having issues when the generator starts automatically, the one inverter is picking up the incoming voltage as over 250V even though tested at the inverter as 231V.
I want to do a firmware upgrade to see if this fixes the issue.
firmware update
Anton Marais avatar image
Anton Marais answered ·
Hannes ek is jammer ek vrae die hierso.
Jy het n jaar terug n smartgen gesetup op n victron multiplus.
Ek sit nou met dieselle ding maar ek is nie seker waar om te begin nie kan jy my miskien help?
Ek het gekyk of ek jou nie kan message nie maar daars nie n opsie nie
Hannes Swart avatar image Hannes Swart commented ·
Bel my 082 880 5287
Anton Marais avatar image Anton Marais Hannes Swart commented ·
awesome sal jopu n lui gee thx n mil man
ahtrimble avatar image
ahtrimble answered ·
I just did an update on my 2 Quattros.
I downloaded the config for each through VRM (VE.connect).
Updated the firmware.
Uploaded the the config for each through VRM (VE.connect).
Then used VE.BusConfig to reset my split phase system.
