teflonking avatar image
teflonking asked
Globalsat BU-353N GPS not working VenusOS 2.89
Globalsat BU-353N GPS (https://www.globalsat.com.tw/en/product-282348/USB-GPS-Receiver-BU-353N.html) I've been told is the upgrade to the Globalsat BU-353S4 (https://www.globalsat.com.tw/en/product-199952/Cable-GPS-with-USB-interface-SiRF-Star-IV-BU-353S4.html) which is documented as working with Venus OS.
  • I have tested the GPS device on my MacBook and it works.
  • I have it plugged into Raspberry Pi running latest stable Venus OS firmware 2.89.
  • I think it is not loading the device on the USB port.
I have all 4 USB ports occupied, 1 being the GPS and I get ...
root@raspberrypi2:~# ls /dev/ttyU*
/dev/ttyUSB0 /dev/ttyUSB1 /dev/ttyUSB2
If I remove the other 3 USB devices and just plug the GPS in I get no USB port device (no /dev/ttyUSB*). I have tried different ports.
Just with the GPS plugged in to one USB port lsusb gives:
root@raspberrypi2:~# lsusb -vt
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
ID 1d6b:0002 Linux Foundation 2.0 root hub
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
|__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/3p, 480M
|__ Port 1: Dev 8, If 0, Class=Vendor Specific Class, Driver=lan78xx, 480M
ID 0424:7800 Standard Microsystems Corp.
|__ Port 3: Dev 9, If 0, Class=Vendor Specific Class, Driver=, 12M
ID 067b:23a3 Prolific Technology, Inc.
The GPS device I believe is:
.. and no driver is specified.
When all USB ports are filled lsusb gives:
|__ Port 2: Dev 13, If 0, Class=Vendor Specific Class, Driver=ftdi_sio, 12M
ID 0403:6015 Future Technology Devices International, Ltd Bridge(I2C/SPI/UART/FIFO)
|__ Port 3: Dev 12, If 0, Class=Vendor Specific Class, Driver=pl2303, 12M
ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
|__ Port 2: Dev 11, If 0, Class=Vendor Specific Class, Driver=cp210x, 12M
ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]
|__ Port 3: Dev 14, If 0, Class=Vendor Specific Class, Driver=, 12M
Does anyone know:
  1. Is my theory that the BU-353N does not have a driver correct? Or does the BU-353N 'just work' for other people?
  2. If it needs USB drivers... does anyone know how to install?
  3. Would it work on a later Venus OS build or the 'large' install?
Thanks in advance.
Venus OSRaspberry Pigps
hardy-tuner avatar image
hardy-tuner answered ·
1. I didn’t see yours on Testet compatibility with cerbo:
  • Globalsat BU353-W SiRF STAR III 4800 Baud
  • Globalsat ND100 SiRF STAR III 38400 Baud
  • Globalsat BU353S4 SiRF STAR IV 4800 Baud
  • Globalsat MR350 + BR305US SiRF STAR III 4800 Baud
2. mook at one, isn‘t supported
3. u stuck at this OS level, you have to make a fresh install with v2.9x
advanture2go avatar image
advanture2go answered ·
Just got it working. It was necessary to set the baudrate to 38400 with the Windows Tool from Globalsat. I was playing around with the device on Windows and higher baudrates to get more sattelites. Plugging it into the CerboGX it did not work. After setting the baudrate back to 38400 it works fine and shows up in the CerboGX
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
