Todd Wackford avatar image
Does Multiplus AC Out 1 and AC Out 2 share the same Neutral?
Does Multiplus AC Out 1 and AC Out 2 share the same Neutral? Are the bonded together and is it a problem if I wire the neutrals together and AC2 Out is tunned off? I don't want to make my campfire inside of RV. haha
Multiplus 12|3000|120-50
TIA
Jangeja avatar image
Looks like the neutrals are bonded together.
Share
sonnenausessen avatar image
Hallo,
kunt u my een config datei toesturen van een Multiplus, omdat ik kontrolieren
wil of myn Mp funktioniert. Hy skakelt alleen Acin 1 met Acout1.
Myn assistend is ESS.
Verwende het om een Eilandoplossing met zelfverbruik te maken.
gvdzandeAto2onlinepointde
groetjes
gerrit
Share
Pat Davitt avatar image
I think the law of "Unintended Consequences" rules here. AC Out 1 and AC Out 2 exist to make power management more flexible. I doubt that Victron would have gone to the added expense of providing a separate neutral connection for both outputs if there wasn't a good reason.
My gut tells me to wire them separately and do not bond the two neutrals together. View of a typical Multiplus is below.
Pat
1 comment Share
this is what you're looking for:
Boekel avatar image
You don't say what version you have, but it should be in the manual.
Share
