Browser running 24/7 as monitor on old 32 bit Acer One Aspire. After a few days and when there is an error the browser freezes.
Update your browser.
I had the same issue with some websites e. G. AliExcess and updating my Firefox did the trick
If your Acer is very old it may not support the version of Firefox needed to run VRM. This ceased being compatible with Firefox 52.9.0 last December for reasons which were not explained.
It does however still work reliably with Remote Console which is what I see you are using.
For monitoring I have got an old Dell laptop running XP hence the old version of Firefox, and I haven't seen this script error message with Remote Console though I occasionally get it with other web sites. So I don't think that is the root of the problem. You may be able to suppress these errors by changing the settings in your browser even if you cannot update it.
Try the Help tab or F1. But I am no expert on the Linux environment.
It's this https://en.wikipedia.org/wiki/Light_(web_browser) version 48.
I've just done a few tweaks which will probably make no difference.
34 People are following this question.
