renfie avatar image
renfie asked
Node-Red Dashboard password
Hello folks,
has anyone ever tried to set the password for the dashboard (https://xxx.xxx.xxx.xxx/ui) on Venus OS Node-RED? I tried in venus-settings.js and in settings.js under /usr/lib/node_modules/node-red, which doesn't work.
Where can I set the setting so that the dashboard is secured?
Node-REDdashboard display
Dirk-Jan Faber (Victron Energy) avatar image
Dirk-Jan Faber (Victron Energy) answered ·
Check the question + answer in the FAQ about it. Also check the part about the configuration files.
