dylan-hyslop avatar image
dylan-hyslop asked
More than 2 MPPTs with Venus GX
Good day,
I currently have 2 * 150/60tr mppts on my solar system. They are connection via VE-direct ports (which the Venus GX only has 2 ports).
How can I go about adding another 1 or 2 150/60tr to the system?
is there no way to get them to sync using Bluetooth or something?
Venus GX - VGXVE.Direct
ejrossouw avatar image
ejrossouw answered ·
If you do a search, you will find some more info on the topic. In brief, you can use USB to VE.Direct cables. Depending on how additional you need, you can also use USB hub, typically powered is recommended. If you have smartsolar, you can create an smartnetwork which is well documented on the Victron site.
