So I've been having a few issues with my v2.89 system. Most notably random ruvvi readings see image. My main thought is that this is being picked up when it drops its BT signal. I've added a long run BT adapter which seemed to solve the problem but now I am back to the same old problem, ghost ruvvi readings. Anyone encounted these and how are they over come. is it just a weak signal?
I've also lost temperature control from my relays which is wierd but might also be caused by t this?
Running GUI mods, was working normally under v2.89
