n55 avatar image
n55 asked
Battery Sense Temp Calibration
Is there any way to calibrate a battery sense sensor reading? I have several and none seem to give the same temp reading when connected to the same battery at the same time. Also tested with a fluke ir temp gun. All read on the low side, worst is off 8 deg f.
Temperature Sensor
Victron temperature sensor disambiguation table - which product supports which sensor
