Can anyone tell me how to connect my Inverter and also preserve the Battery Life Charge Algorithm, so the Inverter will be disconnected on low volatage?
Greetings from Berlin,
Jan
Jan
Hi Jan,
this is a Victron Community Forum, we can not really assist you with your non Victron inverter here.
You must not connect your inverter to the Battery Protect 65. The inverters inrush current would be too much. Even for the bigger Battery Protect units, it is not advised to connect a high current inverter.
I would suggest to buy a Victron inverter and use it's remote on/off functionality...
Regards,
Markus
9 People are following this question.
