chrisr avatar image
chrisr asked
Only one VEConfigure on parallel inverters?
I've recently setup a two quattro 10KVA setup, running single phase parallel.
Initially, I set it up using VEBus System Config, then loaded ESS on both inverters using the software.
I want to tweak a few things remotely, when I go into VRM Portal and remote VEConfigure, it only gives me one config file to download - is this right? I thought I'd have a Master and Slave file similarly to when I did the VEBus config when I had to put the ESS assistant on both inverters.
TIA
Chris
JohnC avatar image
JohnC answered ·
chrisr avatar image chrisr commented ·
@JohnC Fantastic, thanks :)
