jagizzi avatar image
jagizzi asked
BMV-712 Unable to manually set SOC
I took my battery offline to make some system modifications. I screenshotted the status prior so that I could reset to the correct SOC manually when I restarted things. I now find that I am unable to do that, that field, "State of Charge" Manually set the current soc, is not an editable field. When I click on it nothing happens. Am I misunderstanding the use of this maybe?
BMV Battery Monitor
Are you using Victron Connect for this?
If so which version.
Is the software up to date on the BMV?
peterfromswe avatar image
peterfromswe answered ·
I have same problem.
VictronConnect 5.83
BMV-712 4.13
I really want a solution to this. It worked before!
/Peter
5 comments
Try to synchronize it to 100% first.
I also had this issue a few days ago.
kevgermany avatar image kevgermany ♦♦ Matthias Lange - DE ♦ commented ·
Me too. Maybe it should be reported as a bug.
peterfromswe avatar image peterfromswe kevgermany ♦♦ commented ·
To me it seems like a bug. First set to 100% then to x %?!? It worked for me but was a surprise in behaviour.
Matthias Lange - DE avatar image Matthias Lange - DE ♦ peterfromswe commented ·
Thanks for confirming.
I reported it to the developers.
Thanks
Anders avatar image
Anders answered ·
Same issue on a Lynx Smart BMS connected via a Cerbo GX
My take is that this is only available if you connect with VRM directly over Bluetooth or Wifi. The strange thing is than when using the Victron Connect app the Lynx BMS does not show up when on "Local". I have to select VRM, and there the "State of charge is not editable"
