Hi, As per attached diagram if there is 230V supply to the inverter/charger and it is charging the battery and the MPPT is also charging the battery by day, which device now charges the battery correctly or is this wrong?Victron layout.pdf
Both will, it's a normal setup.
If you want to prioritise solar, set the charging voltage slightly higher, staying within the battery maker's specs.
31 People are following this question.
