whjmarais avatar image
whjmarais asked
AC Current sensor distance from Multiplus
My Multiplus installation will be a significant distance from my DB board and ATS, where my generator is wired for backup supply. The area where my main DB board is installed reaches about 35-40 degrees Celcius in summer (direct afternoon sunlight [in South Africa])
The distance is about 15m.
I would like to be able to start up my generator in certain situations, but need to limit current towards battery charging.
What would be the solution for this?
current limit
kevgermany avatar image
kevgermany answered ·
There's an input current limit in the Multiplus. You can set it in your GX device.
