mk1 avatar image
mk1 asked
Grid relay error - everything checked and still cause problem
Hi I have problems with 3 phase instalation with 3 x multiplus II 3000 VA.
On off grid mode everything works fine but when mains is on cause error 11.
Below more details please help to indificate what cause a problem:
Multiplus-IIRelayerror 11
nickdb avatar image nickdb ♦ commented ·
Did this work fine before or is this a new installation and it has done this from the start?
These are the documented recommendations:
Other shown error details, listed below, are not related to any known installation issue and can be caused by a faulty unit or configuration issue. In any case, also when one of below errors shows, make sure to go through all the above steps for any error 11 issue.
  • Failing steps #2-7.
  • Communication error.
  • UMains mismatch.
  • Period Time mismatch.
  • Drive of BF relay mismatch.
mk1 avatar image mk1 nickdb ♦ commented ·
But How Can i fix it ?
PV inverter works fine on this grid on EN505
So multiplus is broken ?
Alexandra avatar image Alexandra ♦ mk1 commented ·
@mk1
Follow the steps for troubleshooting in the manual. To determine if your wiring has an issue or not.
The PV inverter working is not a good indicator. Also answering whether this is a new install or not as @nickdb asked would help?
https://www.victronenergy.com/live/ve.bus:ve.bus_error_codes#error_11_-_relay_test_fault_-_installation_error_or_possibly_relay_failure
