solarq1.pdfCan anyone confirm my setup will be ok with 2 x 5 in series parallel with 3 x 370w and 380w x 7 panels and if my fusing seems correct.
Not a good idea to mix panel types on the same controller. Need more info about the panels to see if it's likely to work. Vmpp, Voc, Isc, temp coefficient and min temp expected. Best is to use the online Victron calculator.
Which easysolar? Appears to be a 3kW Easysolar II at 48V.
42 People are following this question.
