florinb avatar image
florinb asked
7 inch monitor calibration
Hello
I recently purchased such a monitor for cerbo no raspberry pi
https://www.joom.com/en/products/6311db48d54d990179220fdb
When I do the calibration on the cerbo I get the answer from the image
Can someone help me
Thanks
cerbo gx
Kevin Windrem avatar image
Kevin Windrem answered ·
It appears the touch surface is not working.
The link you provided says product no longer available so not exactly sure what display you have or what it's specs are.
I did connect an HDMI touch screen to my Cerbo and it did work even without calibration. The only limitation was it would not dim (common to all HDMI displays) and did not activate screen saver (aka screen blanking).
Cerbo has 3 USB ports but the one closest to the HDMI connector only provide power. Only the other two handle data.
florinb answered ·
Salut
Description
7 inch IPS Touch Screen Module Kit 1024x600 HDMI-Compatible Display Monitor Board Replacement for Raspberry Pi 4B/3B
Feature:
Used as a mini PC monitor.
Support mainstream development boards such as for Raspberry Pi, Banana Pi, BB Black, etc.
When used for Raspberry Pi, it supports for Raspbian, Kali linux, Ubuntu, etc.
The mainstream system single-touch plug-and-play driver-free.
Support for Win10/Win8/Win7 system, support five-point touch plug and play driver-free.
Specification:
Screen Type: IPS Screen
Screen Size: 7.0 inch
Resolution: 1024x600
Backlight Adjustment: Independent Button To Turn On
Touch Screen Type: Capacitive Touch Screen
Touch IC: GT911
Power Supply: Micro USB (5V / 2A)
Video Input Interface: HDMI-Compatible
Audio Output Interface: 3.5mm Audio Interface + 2 Speakers (8Ω2W)
Size: 164.9 X 102mm/6.49 X 4.02"
florinb answered ·
