gerhardlang avatar image
gerhardlang asked
Lynx Pwer in more than four?
Hi, I'm planning a system and I was thinking of the power ins, several next to each other, because I need more than the 4 connections. BMS is in the Pylontechs.
I had seen or read that it makes sense for the current flow on a DC BusBar to alternately assign the connections of the row (in - out - in - out).
If you only use the power in (e.g. 4 pieces), is there a counterargument and could I possibly use more than 4 if the 1000A are not exceeded?
lynx distributor
