In my installation, the Victron Multiplus never goes on float mode charging the US3000C and the current consumption is high.
You’ll find the details in the pdf attached. In summary :
- Why the Multiplus full system never goes on “Float” mode?
- Why the Multiplus does not work the same on battery 1 only and on battery 2 only?
- Why the Multiplus goes on “Float” only with battery 2? It seems that the system is running properly with battery 2 only.
- Why we have different information in the line LMRQ: « External Control » or « State of charge »?
- Why the grid consumption is so high 1.2-1.7 Kwh per 24 h, with zero load?
- What are the charging parameters automatically negotiated between the Multiplus and the Pylontech batteries BMS via the BUS-Can?
Thank you for your help
