Kjell Are Sangvik avatar image
Kjell Are Sangvik asked
Data log Multiplus
Hi.
Is there a way to get a datafile from the Multiplus without connecting it to a GX device? When I troubleshoot and need to see peak power from the AC loads, as an example, can i get this info anyway with only the USB-MK3 or similar device? Or do i have to connect it to a GX device?
MultiPlus Quattro Inverter Chargermonitoring
nickdb avatar image
nickdb answered ·
The VE bus monitor via veconfigure can give some basic info in realtime.
https://www.victronenergy.com/media/pg/VEConfigure_Manual/en/ve-bus-monitor-and-ac-input-connection-timer.html
