After installing firmware V1.61 on my small MPPT 100/20, the load output never switches on. I've tried everything (I think). And yes, I did remove it from both solar panels and battery for 60s to force a reboot. Tx
I have a couple of 100/20s running 1.61 without any load output issues. Check your settings "Always off", Low Voltage and Restart Voltage) etc also check your communication setting to make sure it is set to Normal as the load output I believe could be re-directed to the VE.Direct socket (Pin can be used to control a relay etc). Also check it is not being overloaded causing the output to shutdown
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
39 People are following this question.
