I would like to add another SmartSolar MPPT to ESIIGX, but its GX device has only 1 VE.Direct port (already used for SmartShunt).
Can this be done somehow?
SmartSolar MPPTs dont have usb ports. Edit: You are talking about this cable - The VE. Direct to USB interface cable?
I see low end ones have only ve.direct connectivity (Data communication port - VE.Direct https://www.victronenergy.si/upload/documents/Datasheet-SmartSolar-charge-controller-MPPT-150-35-&-150-45-EN.pdf).
Can 150/35 mppt be joined in a bluetooth network with ESIIGXs 250/70-Tr MPPT, so it would send data readings to it and they would be forwarded to gx device?
81 People are following this question.
