jonkers81 avatar image
jonkers81 asked
Tank level Custom shape point accuracy to decimal place
We are using the Safiery sensor for monitoring aircraft fuel tank levels on our flight line operations. I have setup the system using Custom shape points due to some variation in the tanks.
1. I would like to ask if it is possible to make the Custom Shape percentage points more accurate, to the tenth/hundredth decimal if possible? If you have bigger tanks, it does make quite a difference in liters.
2. Would it be possible when setting up Custom shape point to have a button that says: Use current sensor value? That helps in making it more accurate. The sensor value is often not exact to a whole percent.
We have two tank setups here, one of 1900liter and one of 2960 liters.
tank monitor
